Unconfigures the range of multicast addresses for PIM SSM.
| ipv4 | Configures PIM functionality on IPv4 router interfaces. |
| ipv6 | Configures PIM functionality on IPv6 router interfaces. |
By default, no SSM range is configured.
Initially, no range is configured for SSM. After a range is configured, you can remove the range with the unconfigure pim ssm range command.
When no range is configured for PIM SSM, the switch does not use PIM SSM for any multicast groups.
The following command removes the PIM SSM range:
This command was first available in ExtremeXOS 11.4.
The ipv4 and ipv6 keywords were added, giving an option to support this functionality in IPv6 as well, in ExtremeXOS 15.3.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.1.1 Licensing Guide document.
